sony wx920-bt distortion
mcvibes21
help needed asap. ive been to halfords were found out threres an apdate for this to which following all way says on site n paper on to usb but soon put head unit says updating 0% then file error its becoming iritating as its been built for a sound off car to which cant put volume above 30 as distortion comes in.
its a good headunit but if this aint resovled then it being thorwn
Win_88
Specialist
Hi mcvibes21,
Have you tried resetting the system to factory settings?
I'd also try using a different USB drive as some of the ones I used before had some weird quirks making them not compatible with certain functions. So it's worth a shot.
Win_88
