Sony XB33
Carlroberts
Sony XB33
Hello,
I was wondering if anybody can help me. I have a Sony xb33 Bluetooth speaker and the sound quality is great, it's just the voice over its annoying the hell out of me. It gets to 40% battery life and it constantly interrupts the music to say "please charge". Also when connecting a Bluetooth device and disconnecting one does it honesty have to say "Bluetooth connected". I know it's just connected because I connected it , why does it have to tell me in a really annoying voice. If its telling me to charge at 40% then it really only has 60% battery capacity. Is there any way to turn this annoying voice off?
Thank you for your help
Carl
4 REPLIES 4
Joe_Dohn
Specialist
I'm not 100% if it can be turned off, but from the notes on what you can do with the app, seems like you can adjust the power-related messages.
Carlroberts
Thank you for your response
Win_88
Specialist
It can't be disabled
Carlroberts
Thank you. It's a decent sounding speaker but if you can't disable silly
things like that then it's a deal breaker. I'll sell it on and go back to
JBL.
