Sound skipping on WH-1000XM4
sban0302
I`m having some sound skipping issues with WH-1000XM4.
The tune (similar to the tune you hear when you connect to bluetooth) rings while I play music, which is pretty disturbing....
This happened to my tablet (iPad) and my phone (Pixel 3), but have not tried others because those are the only devices I have...
This happens regardless of the place - in the city, kitchen, or in middle of the city..
It does get better when I prioritize stable connection... not 100%, but doesn`t bother me as much.
However, the fact that I cannot enjoy the best quality kind of disappoints me, and if this is a malfunction of the headphone, I would want to replacement.
Do you guys have similar issues, or maybe any suggestions to fix this situation?
Tags (1)
6 REPLIES 6
Joe_Dohn
Specialist
sban0302
Many thanks Joe,
The tune did go away... but the sound skipping still happens now and then, just without the tune.
I did trying turning off the sensor that pauses when I remove the headphone from my ear, but it still happens.
Joe_Dohn
Specialist
Try resetting them, and failing that go for the factory initialization.
Usually, the reset is enough to counter glitches like this.
Hope this helps!
- JD
sban0302
Hi Joe,
I tried both ways but still having the issue. I guess I will have to ask for replacement...
I also recognized that the bluetooth will be disconnected when I charge the headphone while it`s connected.
Is this how it`s supposed to be?
Thanks again very much Joe.
Joe_Dohn
Specialist
Yes, it's supposed to turn off.
Quote from Help Guide: " If charging starts while the headset is on, the headset will turn off automatically".
Have you received an update about the replacement though?
- JD
sban0302
Hi Joe,
Sorry I haven`t been able to make the tiem tolook into where I should contact for the replacement.
I am happy to accept as solution once I find the form.
Thanks,
Shohei
