My SRS X5 works perfectly when plugged in to AC power. The orange 'charge' indicator lights up when plugged in, as does the green 'I/O' indicator and the Audio In indicator.
However as soon as I unplug it, it switches off. Also, I cannot seem to turn off the unit by pressing the I/O button; it just stays green all the time when plugged in.
Any help would be appreciated. Thanks!
Check the power swplay
What do you mean by check the power supply? I can see the 'charge' orange light switch on and it also works when plugged in. Does this mean the power supply is working fine?
Are there any other checks I can perform?
