Srs x55 Bluetooth speaker
lwade99
I’ve had the speaker for just under a year and two of the small rubber pads underneath have come off and now it rattles on most surfaces. Does anyone know where I can get replacements or even recommend what ones to get.
Tags (1)
Sean_Mc
Moderator
Hi there,
It may be possible to find replacements from EET Europarts.
Hope this helps.
Best wishes,
Sean Mc
