I have two Bluetooth speakers, which are not powering up.
I have fitted a good battery from one of my daily XB20 Speakers.
When pressing the power button, nothing happens, then when left the LED on the power button lights up, then the Extra bass button will light up, and then the front LED will light up, but no bloothtooth or charging lights.
I have tried to get sound through the aux port to no avail. Then I have reset the unit, and tried to initialise, but again if you try to power down, it sits and eventually just powers off.
any ideas would be much appreciated.
Hi there,
It might be best to get in touch with the support team for further help regarding this issue here.
Best wishes,
Sean Mc
