SRS-XB22
NickHarvey52
SRS-XB22
I mostly use this bluetooth speaker for listening to audiobooks but even with all the unnecessary paraphernalia turned off I still only get about six hours of playtime. My phone is right next to it so distance isn't a problem and all the battery draining extras are off. Any ideas anyone,its new as well.
6 REPLIES 6
IamNic
Hey,
at which volume are you listening to music?
- Nic
NickHarvey52
About 70% I guess using a s10 plus.
IamNic
Hello @NickHarvey52,
then the battery life appears normal - the 24 hours are only for 50% volume (or even lower - check the manual/box).
- Nic
NickHarvey52
Ok thanks,to be honest I'm a little surprised that turning it up a couple of notches would make such a difference,but it's not a huge problem after all.
IamNic
maybe that is because loudness doesn't increase linear and therefore e.g. to be twice as loud you need ten times the power instead of just two times. At least that is how I would explain that phenomenon to myself with my limited knowledge in audio.
- Nic
NickHarvey52
Yep,I'm sure you're right. Thanks,I wont ponder any more about it.
