SRS XB22
scottg99
SRS XB22
I was wondering if it was possible to stop other people concerting to the speaker? Like can you put a passcode on it so that I am the only person able to connect to the speaker?
EdwinaU
Moderator
Hi there,
Welcome to the community.
We'll check this and update you when we know more.
Our members may also have some tips for you.
Best wishes,
Ed
Vanilla_
Hi scottg99,
I've checked the User Manual for this model. It doesn't seem that this is possible. But I'd suggest that you reset the speaker to delete pairing information for any device that has been previously connected to the speaker.
Regards,
Vanilla_
