I have had these headphones for about 5 months now and since yesterday my headphones dont automatically connect to the station anymore. I have to turn them off, put them back on the charging station, put them on my head, turn them on and then they work for 5 minutes max. but after 5 minutes they disconnect. the "power" led is turned ON on the station but not on the headphones. help?
Hi @alecool, welcome to the Community.
The first thing to check is the presence of interference from other devices – your mobile phone, for example, may be interfering with the Bluetooth signal.
If you can rule out this as the cause, we can look at other possible issues.
Mick
