Does anyone know where I can get a connecting cable from or if there is a compatible cable
Solved! Go to Solution.
Hi @doppeyxx and welcome to the Community
Do you mean a usb connection cable or the charger?
There are a few usb cables to online in different places eg. Here
(But I can't vouch for that site as I haven't used it)
Another good place is Ebay, although the cables I have seen are more expensive than the other example.
Hope this helps
Hope this helps
