WF-1000XM4 sound gets bad at volume above 60%
ahmedguseynov
For some reason they start to cut the high frequencies out when you increase the volume above 60-70%. Tuning EQ doesn't help much. They sound great at around 60% volume, but then the more I increase the volume, the less high frequencies I get. I'm using them with an iPhone.
Other people have also encountered the same issue:
https://www.reddit.com/r/SonyHeadphones/comments/p7cp0w/heres_your_chance_to_let_sony_know_that_the_...
https://www.reddit.com/r/SonyHeadphones/comments/p62pwx/sony_wf_xm4/
https://www.reddit.com/r/SonyHeadphones/comments/p01opp/wf100oxm4_sudden_quality_change/
5 REPLIES 5
profile.country.NL.title
Strampke
Did you try a reset to check if that solves the problem?
Bat_Rick
Hi Ahmed,
I would recommend to reset the unit, make sure that the software version is the latest: https://www.sony.co.uk/electronics/support/wireless-headphones-bluetooth-headphones/wf-1000xm4/softw...
ahmedguseynov
Resetting didn't help 😞
ahmedguseynov
I've tried resetting them, it didn't help. I'm using the latest firmware version (1.2.6)
SkyNet404
Specialist
Hey @ahmedguseynov
Does this have with a specific device?
Or, with all the devices you tried it with?
Cheers.
