wh 1000 xm3 forcing unwanted Google monitor
dofgod
If I want to update my expensive headphones I must now accept Google Assistant installation. Thanks Sony. I will never trust you again. So sneaky. How did Google make you do it?
IamNic
Hello @dofgod,
with the new update you have the option to use Google Assistant and Amazon Alexa.
Assuming you use an Android smartphone - Google Assistant is already on your phone - it though is not mandatory to use it - same goes for the headphones. It is an option!
- Nic
