WH-1000MX3 only charging when turned on
Pimplychuds
About a month ago I plugged in my WH-1000MX3s and they wouldn't charge. After resetting them and following instructions from various forums, I noticed they would still charge when the headphones were switched on. Obviously this is the exact opposite of how they are meant to work. I've seen a few other people on other forums mention this issue, but as of yet haven't found a solution. Does anyone have any ideas?
I guess it's not a huge issue given they do still charge, but I am concerned that charging them whilst they're turned on might damage the headphones in some way. Would this be the case?
Thank you in advance for any help!
Piscie
Community Team
Hi @Pimplychuds, it seems to be a bug so you can try initialising it, link from the manual: https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703081.html
Also try a different USB cable if possible.
Pimplychuds
Hi there. I have already tried both of these options and neither have worked. Are there any other possible solutions?
