WH-1000XM3 crackling and low rumble on right cup
jljunk1
This is the second pair of these head phones I've had and it's now having the same problem as the last pair which I returned.
The right side cup has a crackling sound or a sometimes a very low level rumbling sound. It used to be infrquent but seems permanent now.
I disable ambient sound in the android app the crackling and rumble disappears.
Seems to be a common problem with these headphones.
Is there any hope fo a fix? Or time to return them??
Tags (1)
Pascale_F
Moderator
Hi jljunk1,
Welcome to the community.
I'll just see if I can find any help regarding this. In the meantime though, maybe another community member might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi jljunk1
I read somewhere that this is related to air pressure and noise cancelling. Have you tried re-calibrating NC using the Sony Headphones Connect?
Perhaps an update: https://www.sony.co.uk/electronics/support/wireless-headphones-bluetooth-headphones/wh-1000xm3/downl...
or a factory reset: https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703081.html
Win_88
