Sony - what have you done? the WH-1000XM3s that I bought (running firmware v4.1.0) are no longer class leading noise cancelling headphones.
V4.1.1 and now v5.0.0 have destroyed the noise cancelling performance - this is so disappointing.
For anyone else with this problem, I have found a v4.1.0 apk download..... I have just installed and will check later when I am travelling on the train again (known reference for noise cancelling performance):
On Android:
I really hope this fix works and that Sony fix V5.x.x very swiftly, or I will likely be heading back to where I bought them to exchange XM3s for QC35ii - it was a close call on which was best before 4.1.1 , but its not any more.
Same problem, Sony states that the ANC was untouched during the update hinting to the users 'imagining' this issue. It would be nice if we could just roll back to a previous version of the software on the headphones.
Does the Apk back rev the firmware on the headphones themselves, as well as the android app?
All, I've corrected the title of this thread as I have rightly been corrected that it is the android app and not the XM3 firmware that I refer to below. The bottom line though is that I think reverting the android app version back to V4.1.0 has solved the problem and I've updated, with a little more detail below, how I did it (I hope it helps):
For android:
Is it a prank? How can this work? App version do not influence on hp work.
no really - I'm running V4.1.0 again and after a journey back home on the train, I'm pretty sure its back to how it was. I haven't yet understood the interaction between the app version and the firmware version, but I get the feeling that the change is connected in some way to the functionality of the 'ambient sound' setting in the app.
Anyway I think its worked for me and I've had no issues with the APK , so was just sharing what I've found.
Jimdib - I'm not sure at this stage, but see my updated posting
Sorry, I've tried this and no difference.
@Aleksunn wrote:Is it a prank? How can this work? App version do not influence on hp work.
No, but the App has direct control over how the XM3s operate (e.g. level of ambient noise allowed in etc etc ) - that's what its for! - We have no idea what changes Sony make with each App version 'update'
