WH-1000XM3 won't charge except when on.
motolola
I bought the headset about 5 months ago, Good build quality, everything is perfect, enjoyed the noise cancelling etc.
The issue is, whenever I tried to charge it while the headset is turned off, it just wouldn't charge, the red light wouldn't come on as well.
I always have to put it on before I plug it of which it behaves normal.
The problem is how do I charge it if I ever drain the battery to zero, and am unable to turn it on before charging.
How do I resolve this issue?
I do use its supplied USB-c cable on my macbook to charge it.
Tags (1)
IamNic
Hello @motolola,
have you tried a different charger instead of the macbook?
I would try to use a smartphone charger (no speed-charger, since they don't work) to see if it may be an issue with the macbook.
- Nic
