WH-1000xm3 won't power on and charge
profile.country.KR.title
gms107
Hi Guys,
I saw a similar issue on the board but the situation is a little bit different.
my wh-1000xm3 suddenly won't power on and charge. Even I tried 2 reset method(press 2 button together with USB and without USB). but it won't change anything.
if I plug USB to headphone, there is no LED anymore.
I think this happens after fully discharged. I had charged over 3 hours. even LED is not on.
Should I go to repair center?
IamNic
Hello @gms107,
which charger do you use?
Try a 5V 1Amp charger if you use some kind of speed-charger.
- Nic
gms107
I used  3 type of charger. first one is PC with windows 10. second one AC charger from samsung galaxy. third one is USB PD charger compatible with QC 2.0
