WH-H900N - Bass volume and EQ-settings via App.
profile.country.DK.title
Kthorup
Hi Community
I am very interested in this product as i like the features (except maybe for the powerfull Bass).
There are no shops nearby that have them for "hands on" - only online...
Therefore i would like to know if the EQ-settings from the app still apply if i use a cable, as long as the unit is turned on?
I have read that the Bass is quite powerful - can it be turned down "naturally" in the app or is it still dominant whatever you do?
How is the sound-setting when using it with power off?
Thanks!
Tags (1)
Pascale_F
Moderator
Hi Kthorup,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Kthorup ,
I believe that it is not possible to adjust the equalizer settings when it's connected via cable. I haven't tried that to be honest but I found this link in the Help Guide: https://helpguide.sony.net/mdr/whh900n/v1/en/contents/TP0001515063.html
Cheers,
The_Black_Rose
