What type of audio files can be bookmarked by NWZ-W273 when charging?
One thing I don't like about my beloved NWZ-W273 is that it doesn't remember where I am in my audiobooks when I have to charge it. But one day it seemed to remember where I was! Does anybody know what types of files that works for?
By the way, does anybody know exactly what types of files NWZ-W273 can play?
Thanks!
Tags (1)
Hi there
This player supports the following:
File Format
Audio Formats (Codec)
MP3
Media File format: MP3 (MPEG-1 Layer3) file format
File extension: .mp3
Bit rate: 32 to 320 kbps (Supports variable bit rate (VBR))
Sampling frequency (*2): 32, 44.1, 48 kHz
WMA (*1)
Media File format: ASF file format
File extension: .wma
Bit rate: 32 to 192 kbps (Supports variable bit rate (VBR))
Sampling frequency (*2): 44.1 kHz
Linear PCM
Media File format: Wave-Riff file format
File extension: .wav
Bit rate: 1,411 kbps
AAC (*3)
Media File format: MP4 file format
File extension: .mp4, .m4a, .3gp
Bit rate: 16 to 320 kbps (Supports variable bit rate (VBR)) (*4)
Sampling frequency (*2): 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz
(*1) Copyright protected WMA files cannot be played back.
(*2) Sampling frequency may not correspond to all encoders.
(*3) Copyright protected AAC-LC files cannot be played back.
(*4) Non-standard bit rates or non-guaranteed bit rates are included depending on the sampling frequency
In regards to the bookmarks - i dont know im afraid.  You might want to contact Sony Support for that one.
