Which headphones should should I choose.
IanChelmsford
Hello - which headphones would you recommend I should select for use with my electronic drums and also to use with a mixing desk.  I want something with a flat frequency response but good isolation from ambient noise to cut out the sound of my sticks hitting the pads.  I have a pair of MDR V150 headphones - I like the sound from them, I love the robust, long cable, but the on-ear design lets in too much of the background noise.  I'm only looking for wired headphones - any latency due to wireless really messes up the drumming!  Thanks for your suggestions - Ian.
Peter_S.
Genius
Hi Ian,
I would recommend the MDR-1AM2.
https://www.sony.co.uk/electronics/headband-headphones/mdr-1am2
They have a nice flat sound and a quite good isolation of surrounding noise.
I would say they're a perfect match for your needs.
Personally I own the first generation of them and I'm still happy with the quality and sound.
Peter
