Hi, does Sony have any Windows app similar to one on mobile phones or what do you recommend to use for sound settings and for using buttons (next, previous song) on headset properly?
WH-CH700N
Hi Yzergin,
I don't think that Sony has developed an application for the headphones on PC. I only found a link to download Headphones Connect on the official support page of the product, which can be downloaded on Android and iOs devices only.
Also, I've seen in the Help Guide that if you're connecting the headphones via Bluetooth to the PC that supports HFP/HSP, you can actually use the buttons to move to the next/previous song. You can find more information here: http://bit.ly/2VfRcXY.
Cheers,
The_Black_Rose
Have you tried the "Sony Music Center for PC" you have plenty of sound settings within the application, although, saying that, I've never used the next track on the WH-H900 headphones headset?
