Wireless Headphones WH-CH710N
Swallow43
Hi all,
I have purchased a new set of Sony Wireless Headphones which I am trying to connect to my Sony Bluetooth Stereo Turntable (PS-LX310BT)
The Sony website states these devices are Bluetooth compatible, and whilst the devices have connected, I am only receiving sound through the right hand earpiece 😢
The headphones work ok when connected to my Amazon Fire table via both Bluetooth and cable connector.
What am I doing wrong?
Many thanks in advance for suggestions 🤔
Peter_S.
Genius
There's not much that can be done wrong.
I would say that there's a technical issue with the turntable and would recommend to send it to repair.
Peter
Swallow43
Thanks Peter.
Even though I have only just become aware of the problem, unfortunately the product now out of warranty, but I have arranged for a Sony repair centre to have a look at it to see if it will be cost effective to repair. Fingers crossed
thanks for your help 👍
Joe_Dohn
Specialist
@Swallow43
It might also be worth trying a different device with the turntable (BT speaker or other set of headphones).
