3g connectivity
austinman
3g connectivity
I have the wifi enabled tablet not 3g model can I connect a 3g usb dongle to the tablet to gain a 3g connetion when there is no wifi available
mpattenden
In a word No.
You cannot use a USB dongle. What you need is something like the the Three MiFi device that allows you to connect over wireless. I have one of these and it works very well - you can connect multiple devices at the same time although performance will decrease as more devices are added dependant on what you are doing obviously.
HTH
Padster
GeoffNT
Not really an answer to your question but do you have a 3g phone? On holiday recently we stayed at a place with no wifi and I just set my phone (HTC Desire) up as a wifi hotspot. That way I could connect both my Tablet S and my wife's laptop to it through the normal wifi on both. Given a half-decent phone signal it was pretty quick too. Just a thought and it saves buying a separate 3g dongle.
mpattenden
In a word No.
HTH
Padster
austinman
I can use the phone as a hotspot but have only a 1 gig allowance plus the battery on the phone seems to bbe eaten up quickly. was hoping a dongle may be the answer will have to purchase extra mb's  from Orange when I get out in the camper
