Connecting toInternet via T-Mobile sim card.
bipopboopyblop
I have recently purchased a Sony Tablet S. I already had a T-Mobile dongle for my laptop which had quite a lot of credit on it so I removed the sim card from the dongle and inserted it in the tablet. It worked fine when I first used it. It went straight to the T-Mobile web n walk page where you purchase 1 or more days use and then connected fine. The problem now is that it just doesn't want to connect and I just get a web page that says 'no Internet connection'. Does anyone have any advice on what could be the problem?
jackbarr
Posted this elswhere but I had a similar issue with a 3 sim - I resolved it by going into Settings and switching off Wi-Fi - I was then able to access the three website. Might work for you as well?
bipopboopyblop
No one have any ideas on this problem???
jackbarr
