Delete music
ritchieboy94
Delete music
How do u delete music from the sony tablet i cant figure out how ????
thejudge
You can use the file transfer app to do this.  Go to the music folder and find the file,  select the file you want to delete by touching and holding the file.  select delete from the popup.
thejudge
ritchieboy94
thanks worked perfectly
