I wanted to install the Blackberry Enterprise Solutions according to our IT-department. I did all the work, however, the BES Work Manager didn't open. After restarting my device, it doesn't work anymore.
I am in an endless "booting" mode, the blue waves of Sony... I tried a hard reset with on/off button and volume up. It shuts down the tablet, but when starting I get the same blue endless waves...
Can anyone help me? I am also willing to do a factory reset, but all my google search didn't work. (I cannot get into recovery mode by clicking volume up/ down when starting new).
Thanks, Stephan
Solved! Go to Solution.
You need to perform a system repair using PC Companion - This will factory reset your phone and erase all data which is something you can't evade unfortunately
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
Thank you!!!
