The message you are trying to access is permanently deleted.
Solved! Go to Solution.
I am not sure that it's possible. Take a look at this thread:
http://talk.sonymobile.com/t5/Xperia-Tablet-Z/Multiple-Users-and-SD-card/td-p/358194
Hope that helps.
Partha
Hope that helps.
Partha
