Move apps to sd card Xperia z3 tablet compact
untravel
I put 5 games and the internal memory is full. Also, I inserted almost empty sd card.
Why did you insert the SD card slot, if it can not be used normally?
Do you plan to add a "Move apps to SD"  function to the next firmware, llike in Xperia t2 ultra for example?
Thommo
Genius
Probably not as it was Google who removed this feature - When KK is released then I'm almost sure due to encryption this feature will not be available, Well that's according to Google
Thommo
Genius
untravel
Google does not prohibit to add this feature. For example, I owned a nvidia shield tablet, it worked apps to sd and transferred  cache to sd card without root
