no sound
preedy
no sound
Hi can anyone help I have an s tablet that I received last xmas, until now I have had no need for the sound,but now I need it, its not working. thanks in advance
Thalamus.
Champion
Hi preedy,
Open Settings, then open Sound.
In Sound open Volume..
Does it show your audio is muted.?
If so close the settings screen & then press the + volume button on the right hand side of the tablet (next to power button) hopefully this should remove mute & restore sound on your Tablet..:smileyhappy:
Thalamus.
Champion
Hi preedy,
