Cheers all
As the title says - I have just time and so the date... Which is quite frustrating and unconvenient - everytime I have to dig through settings to turn on the wifi and so on... I I have to say that on my Xperia Z smartphone everything is fine and I DO have notifications/quick settings bar after the same update I did on friday... Any help, suggestions would be very welcome... Thank you and have a nice day
Witkacy
Solved! Go to Solution.
If you pull down the status/notification bar on the left side of the tablet you will see the notification panel. If you pull down on the right side you will see the quick settings panel instead.
Alexander, any idea when the 4.4.2 update will come to USA on the SGP311?
Unfortunately I don't have any information when it will be available for your unit. The firmware update is rolled out gradually and may differ depending on market/region and customization. I suggest that you wait for the notification in your tablet or connect it to PC Companion from time to time.
talk.sonymobile.com/t5/FAQ/The-software-update-collection-topic/m-p/348066#U348066
