Sony Playstation 3 Keyboard
Orbitric
Will the Sony Playstation 3 keyboard work ok with the Xperia Z tablet or can anyone reccommend a better one.
Hi there
If your talking about this PS3 Keyboard : HERE
Looking at the reviews on Amazon, this reviewer : HERE - suggests that it does work with android
Another option to consider, which seems to have lots of good reviews is this one : HERE
Hope that helps.
Hi there
Hope that helps.
Orbitric
Thanks for your help
