Hi all.
Having problems with this recently. When I run the app it tells me that I must download an update. I do this, am told in the notification bar that it has downloaded, try to run it again, and the message comes up again. Loop until disheartened :smileyangry:.
Any ideas how to fix this please?
Solved! Go to Solution.
If I remember correctly, you need to tap the notification bar (does it show as a tick). That will bring up a small box telling you it's downloaded, then I think you tap again in the box and it will install it.
At least thats what I remember doing....
Many thanks, so simple and yet not at all obvious!
Simon
