Where's my lock screen gone?
drdeej
Recently I installed Go Locker and changed permissions to allow GL as my main locker. However, I got bored of the lock screen always being in portrait so I removed and I cleared all defaults. In fact, I reset all defaults on my tablet. I cannot find the stock Xperia lock screen though. I have been in both personalization and display but no option to activate. I have enabled the double tap to wake up and changed the wallpaper for the lock screen but still nothing. Can anyone help?
Thommo
Genius
Sounds like you need to open Settings then Security and turn on a security setting like Swipe - If it's set to None then there will be no lock screen
Thommo
Genius
