wifi shuts when tablet shuts no notifications help
beejan29
when i start to download any file which is big ,after the screen goes black after 1 minute the WiFi also stops working i have to start the machine again and the WiFi starts to work again and the file starts to download again
it means that i wont be getting any notifications while the screen is off as the WiFi is off .not nice
any way of getting around it
thanks
Message was edited by: beejan29
4 REPLIES 4
michaelb104
In wifi settings change the disconnection  policy  to never , hopefully this should fix it.
Cheers.
profile.country.nl_NL.title
breedBenR
you can also set the screen timeout setting to a longer interval
you can also install a screen timeout toggle widget from the market, and use that to keep wifi alive.
you can also use thet setting Applications Development 'Screen will not time out when charging'
gugabackhand
Updating your wireless driver would help too. You can first check if there's one available. https://imagicon.info/cat/12-13/vmware_happy.gif
Thalamus.
Champion
What are you talking about, it's a Tablet S so it's not possible to update the driver..:smileyshocked:
