Z2 tablet Radio app not recognizing any headphones
hannelore55
FM Radio app keeps asking for headset. Latest attempt with Sony MDR-E9LP headphones, 13.5 mm plug. Any advice on this problem?
hannelore55
Got a new headset from the nearest Sony Service (in Sweden) by mail today. Tested it a few minutes ago - works perfectly. And what is most amazing: all other headphones also work now. The differences between the old and new headphones are that the new set has a small on-off switch and that the new plug has three "rings" instead of two. So it's a four-conductor connector.
Happy again with my tablet!
Riitta
A former computer professional : D
5 REPLIES 5
Uliwooly
Are you using Sony's headphones?
SergioPL1
He just said that he is Winking_Face
Are other apps playing through headphones without issues?
Try to restart Radio App. Settings / Applications / All / FM Radio / Force stop & clear data.
It will erase stored stations.
hannelore55
Hi all,
The tablet does not recognize headphones at all, in any application. So there must be something wrong with the connection. All headsets work perfecly in other devices. Have to take my tablet to service.
Thanks!
Riitta (Ms)
SergioPL1
Keep us updated Slightly_smiling_Face
hannelore55
Riitta
