When my tablet is at 0% and off, it charges up until the screen powers on to the powered off charging screen. Once it hits 1% here, it stops charging. When I turn it on at 1%, the red light that indicates charging comes on for a couple of seconds when the screen is off, before stopping when the screen turns back on.
Any ideas?
Hi @OuterYacht,
I'm sorry to hear this.
There are a few things you can try to see if you can get your device to charge, try these tips one after the other checking after each one if there is any change.
Keep me posted if there is any change after trying these tips.
Hi @Emil
Thanks for the tips
I tried the things you mentioned, but there was no change.
