Z4 tablet speakers operating, with headphones installed.
LHL2500
The speakers on my Z4 tablet is operating, even though I have headphones installed.
I get sound in my headphones, but also from the speakers (though at a lower volume).
I doesn't matter what headphones I'm using, I've tried my Sennheiser's and my Sony headphones. Same result.
And the headphone jack is fully pushed in.
Hampus
Champion
After you've cleared data for Smart Connect, I suggest that you also restart your Tablet.
profile.country.US.title
Qatrium
@LHL2500
Try refreshing your Smart Connect app:
- Go to Settings -> Apps -> Smart Connect -> Force stop, Unistall updates, Clear data.
- Go to your Play Store and update Smart Connect again.
Hampus
Champion
