Sony W67 32 KDL-32W653A How to fit stand?
How do u fit stand to this? Think i might be missing some screws?
Hi there
Instructions on how to fit the stand, as well as quantities of screws etc are : HERE
Hi there
Hmm i only have 2 screws in the box, could i just go to a diy store and buy 2 more?
Yep, that would work just as good - just match it up from B&Q or Wicks or who-ever.
