Is my Bravia VESA compliant??
Ann2016
Not sure if I'm in the right room?    I've bought a new Sony 43"TV, therefore want to move my 32" Bravia on a wall in bedroom.  Previous owners have left holes where mount was fitted, however I have been unable to find suitable mount.  The screws on the back of my TV are 20 x 30 - I've now seen that everywhere shows symetric sizes (e.g. 50 x 50 etc).   Does this mean I can't fix my TV to the wall?    If anyone has had this problem can you recommend model of wall mount?
Thanks. Ann
IamNic
Hi @Ann2016,
there are non-symetric Vesa mounts for the back of the TV.
Much more interesting though is the part that mounts to the wall, since you said you want to re-use the holes which are already in the wall.
- Nic
