recording
kenswin
recording
how do you record on the tv....Thanks
Sean_Mc
Moderator
Hi kenswin,
Can you please tell me which model of TV you are using?
Thanks,
Sean Mc
Iain_mack
If you are using youview then it won't record you will need to disable it
Go to home, settings, channel setup, youview setup and disable it
I hope that works for you
