VGN-NW20EF @ key not working properly
V8Lover
I cannot find an appropriate board on which to post this message as there seems to be nothing for laptops.
I have a VGN-NW20EF laptop and the @ key does not work with the Right-shift.
Everything else works with the Right-shift, and the @ key works with the Left-shift.
I have uninstalled the keyboard driver and re-booted, upon which the driver has been re-installed, without any change.
Has anybody got any ideas how I can get it working with the Right-shift?
4 REPLIES 4
LightFoot
Specialist
V8Lover
Thank you. I clearly only looked at General Chat. I will re-post
V8Lover
Being new to this site, I marked this solved, thinking I was marking that posting on the correct board was solved.
It appears that I have marked my problem as being solved. Is there any way I can get rid of that?
Many thanks.
royabrown2
Hero
@V8Lover
Best left solved isn’t it?
Otherwise we are going to have an issue on this board that will never be solved, and will skew our statistics 😢
