After oreo update, I've got no signal.
Is there any news about the problem with no signal after update to Android Oreo?
My Phone (xperia X compact) read sim card but it can't connect to network (mobile data, calls and SMS don't work).
WiFi works OK.
Is there any solution to this.
I have a sony x as well and after the latest upgrade, my sim has no service at all. But it works in other devices.
Hi @leonardo36, sorry to hear about this.
I have answered the private message that you sent me, so please have a look in your inbox!
I am having the same issue. Is there a solution to this problem? Could you post the answer here?
Hi @lisa_a24, sorry to hear that you are experiencing the same behaviour.
I recommended that @leonardo36 tried with a different SIM card in the device, and if it was still not working, the next step is to perform a software repair using Xperia Companion.
The repair will delete all data from the internal storage though, so it's important to create a backup using Xperia Companion before starting with the repair.
Let me know how it goes for you!
Hi @lisa_a24 and @Jonas,
I had to take my phone to the sony repair centre closer to me. Seems like it had a mainboard issue and they had to replace it. Lucky I was still under guarantee.
Seems like it cannot be fixed manually but only at the centre.
Thanks for the advice Jonas
it seems that the hardware failure was casual, since so many users have the same problem. I have posted this before. I have already tried with software repair, factory reset, Sony Flashtool, etc. nothing works.
Are you sure that it´s not a firmware issue for this specific model? is there any official statement that Sony could release regarding this issue?
Unfortunately I have bought the mobile in Amazon Germany, while I was working there, but I live in Argentina, and Sony XperiaCare doesn´t want to check my unit for that reason (it seems not to be a global company like Apple, isn´t it?)
Kind regards
@leonardo36 wrote:I had to take my phone to the sony repair centre closer to me. Seems like it had a mainboard issue and they had to replace it. Lucky I was still under guarantee.
I had the same Issue: No RF Signal - no software solution helped so I decided to check the hardware. The SIM Card Reader was fine but on the mainboard in the vicinity of the antenna connectors I found a destroyed tiny BGA chip. I cannot say what it is but it looks like an RF switch due to the surroundings.
Any Idea what it is and why it broke?
I am sure that I did not break it mechanically during the dissasembly. The missing parts are not there so I cannot decipher the labeling.
Possibly an electrostatic discharge on the antenna killed it??
Looks like a Qualcom QFE2550 Antenna tuner
I wonder if replacing it can fix the issue...?
Did you find the solution? Could you downgrade your phone?
