Unable to reset Xperia X Compact
roxwindy
Hi there,
I updated the phone to Android 10 and I was not able to unlock my phone anymore.
I tried to use Xperia Companion to reset the phone to factory settings but it says that the device is locked and unlock is required to repair the phone.
What should I do? I do not mind losing all the data in the phone.
profile.country.NL.title
Strampke
Hi @roxwindy
Try this:
  • switch off your device
  • start Xperia Companion
  • tick the option in the lower left corner of the screen that your phone cannot be recognised or is a smartwatch
  • good luck repairing!
pseudonym
Android 10?  There is no upgrade to Android 10, or even 9.  The Xperia X Compact began at Android 6, was upgraded to Android 7, and then 8, where it remains. Perhaps you meant Android 8?
