I have to add to the already existing posts about the volume buttons only adjusting media volume unless you press the options gear. I am also a little aggravated with this current setup and wonder how an update that makes extra steps for something that should be accessible without entering options even got approved. Then there's also the matter of slightly larger and less sleek looking icons in the pull-down menu. Not pleased with the appearance and functionality changes in this update.
This complaint is to the point. Should have been addressed by Sony as atleast on the on main screen, the volume keys should work as for ringtone volume and not for media.
