Clock size
Hello
Can you tell me if it is possible to resize the size of the clock on the home screen, in smaller.
Thank you
Taille de l'horloge
Bonjour
Pouvez-vous me dire s'il est possible de redimensionner la taille de l'horloge sur l'écran d'accueil, en plus petit.
Merci
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
If you long press the clock on the lockscreen > swipe left to right to see other options, if you don't like those options, you will need to download a thirdparty lockscreen app
