Google Play store
Memphis_267
Google Play store
I can't update my App's at all on my Sony Xperia XA ultra
Uliwooly
@Memphis_267
What if you move the apps to the internal storage then clear PlayStore cache > retart the phone > check again
Befilled
I've had the same issue on the same type of phone. I have unloaded many apps and I am able to reload them but it still won't update 15 of the apps on Google Play Store.
slumdawgcpt
Had the same problem...
format sd card and re - install apps on phone memory not sd card. You will now be able to update as usual. Not sure if this was the same on previous versions of android.
