I need to change the way the phone opens this and another external links. When I tap on the green button (to link with my My Nintendo account), the phone opens a floating browser (ignore what it says) but it's annoying instead of being useful. Please, help me, it happens with other apps
Solved! Go to Solution.
I have something preinstalled called Google App, but it isn't that. And I reinstalled the app like 6 times but... nothing
Edit: okay, I found the solution! If you go to Settings > Apps > Show system, and you disable the "setup wizard" thing, you can open things with the browser itself. Thank you very much for helping me ^^
How do I disable wifi calling
