Just purchased the Xa2, how do I put the micro SD card in the tray isn't easy to get out don't want to damage it
This should guide you through the process:
https://support.sonymobile.com/global-en/xperiaxa2/userguide/assembly-ss-content/
Do not cut your SIM card, as this may damage your device. |
When I pull out the SIM card tray there is only a holder for the SIM card and not the memory card and there seems to be something blocking the memory card slot which won't come out. Is my phone setup for a single SIM and no memory card?
Many thanks
