How to get on "quick charger"?
Mambarambath
Jonas
Master
Hi @Mambarambath, welcome to our forum!
The Xperia XA1-series supports the MediaTek Pump Express Plus 2.0 technology and you'll need either the UCH12 or the UCH12W quick chargers to charge your device faster than the original charger that was included together with your device.
The only difference between the chargers are the cables included. The UCH12 comes with a micro USB cable, so you will need to use the USB cable included with your device, but the UCH12W comes bundled with a USB Type-C cable, so you can either use that cable or the one included with your device.
Let me know if that helps! Slightly_smiling_Face
