How to put a call on hold when I receive another call?
Laykazuz
Hola quisiera saber como le puedo hacer para poner una llamada en espera cuando estoy en otra llamad
Hi, I would like to know how I can put a call on hold when I'm on another call
-GT
Jonas
Master
Hi @Laykazuz, welcome to our forum!
I have translated your question to English as this is an International forum, please post any replies in English and will be easier for me and other users to assist you.
If your operator supports the service called "Call waiting" you will be notified when you have a new incoming call, during an active call and you can choose to answer the incoming call and the person you already had a call with, will be put on hold and you will have an option on the call screen called "Swap". This function always you to swap between the calls.
You can find call waiting if you open up the application called "Phone" > 3 dots in the top right corner > Settings > Calls > Additional settings. To activate or deactivate call waiting, tap the switch beside Call waiting.
If you are not sure if your operator supports this feature, please contact them and they will be able to answer this for you.
I hope that answers your question! Slightly_smiling_Face
